    Default Openbox S9 - freezing and can't change channel
    Someone has given me an Openbox S9 - and asked me to figure out what's wrong with it. It freezes and when it does that, it's not possible to change channel.
    I have not started to troubleshoot it yet but given that there are many openbox users here, I wondered if these symptoms resonate with anyone here?
    The first symptom could be a whole load of things - from the box end to ...erm...afar. However, I'm guessing the secondary symptom - i.e. not being able to change channel while this happens means this is an issue with the box itself?
    Would be grateful for any opinions.
    DK Veteran slugworth's Avatar
    Nov 2011
    new england
    probably a heat problem.
    pop the cover off and put a fan on the processor,like an old pc cpu type fan.
    Jan 2013
    had the same problem ( don't laugh) all I did was change the batteries in the remote,
    and it worked straight away no probs since
    cant see why itwould affect the box but it did
    worth ago at least
    May 2012
    Quote Originally Posted by valhalla1 View Post
    worth ago at least
    Batteries in the remote control will not have any affect on a box freezing.
    The most common cause of freezing has already been mentioned by slugworth.
    If the op is not confident enough to fit a laptop fan then there are cheap (under ?2.00 delivered) USB cooling fans on the bay.
    Nov 2011
    new england
    I just had to do the fan thing on my s10 a few months ago.
    It had been working fine for about 1 year.
    It would freeze after about 1 minute of being turned on.
    Hadron's Avatar
    Nov 2012
    E. London
    Failing capacitors on the PSU board could also cause different intermittent problems until they fail completely.
    Have a look at C19 on the PSU board (it may be 1000uF or 1500uF @ 10v or 16v). The top should be completely flat with no bulging.
