Results 1 to 9 of 9
    Jan 2014
    Default how to install enigma 2 on dream box 500
    hi D-Kaos
    I want to install enigma 2 on my dream box 500, i found a guide thanks to digicon that teaches how to flash a dream box in two minutes..
    Im currently searching for a recent image of enigma 2, but I have a couple questions..
    the install is it as simple as just flashing the box with enigma 2, using the guide found here
    http://www.digital-kaos.co.uk/forums...2-mins-224293/
    or do i need something like openPLi installed first or something..
    this is my first ever setup and if my question sounds a little stupid, sorry bout that i really am a noob when it comes to this setup.
    digicon's Avatar
    Jul 2009
    I am afraid that the DM500 is Enigma1 only and there is no chance of you flashing an Enigma2 image to the receiver.
    Jan 2014
    how depressing, i can never catch a break ..
    is that including 500 se?
    digicon's Avatar
    Jul 2009
    Quote Originally Posted by s4mmy View Post
    Again there is no 500se there is a DM800se and a DM500HD which both are enigma2 based receivers
    Jan 2014
    im trying to connect to my dreambox via flashwizard pro but it wont connect and says to check the connection perimeters..
    do u know what that means?
    ps.. on the actual box it says dm500-s
    I have also located the setup password and can get into setup now, but if i try use that password with root when connecting via flashwizard it says password is wrong and to check parameters but if i dont use a user n pass its only says to check the connection parameters so i think i dont need user/pass but need to work out what the connection parameters are..
    ok well i just tried connecting via ftp and user/pass is wrong, its not the same as setup and if i try connect without user pass it adds anonymous to username and then again says user/pass is wrong.. what a pita
    digicon's Avatar
    Jul 2009
    Standard User/Pass on all DM's is root - dreambox the root part can never be changed the password can though
    Jan 2014
    i am assuming the ftp password os different then the setup password..
    for the web interface i dont need to login, it just acesses the page straight away..
    I do have setup password now but i couldnt find where to go to change the ftp password etc..
    i cant login with flashwizard or ftp and would be good if i could change the password via the dreambox setup menu..
    only other option is to do a complete factory reset, but i want to leave that as a last resort..
    DK Veteran psats's Avatar
    Sep 2008
    ftp pass is same
    ie
    192.168.xxxxxxx
    root
    dreambox
    Jan 2014
    my pass may of been changed by the person i bought it off a few years back. i have full access to the dreambox it self, but I can not login remotly via ftp or flashwizard etc..
    i even disabled the password to get into setup on my dreambox but it didnt help.. i also tried the default root/dreambox login via ftp but it didnt work.
    is there a way to change the ftp password via the dreambox it self..
