hi can any one help is there anyway i can recover a skybox s12 box becoz theres no rs232 conncet on the back of the box
hi thanks DW190 for your replz yrs it is mate
You need something from this lot.
rs232 to ttl converter | eBay
hi again will have to open the box to fit it rs232 ttl conveter im all new to sky game
Put a post with a rough guide to area you are in mate im sure someone near you could help
hi dus anyone know what color go's to what pin when im useing rs232 to ttl converter on my skybox s12 ?
no need for the converter,the 4 pins are rs232 and not ttl.
you need a 4pin converter to 9pin.
use an old pc cdrom 4pin audio cable
hi will this work mate
hi dus anyone know if i can use's one of theres rs232 to ttl converter
on a skybox s12 ?
I would give up looking at ttl converters, as you won't find what you need.
You will need to make your own. If you haven't got an old connector from a pc you can use, then the connectors (with wires attached) can be found on Ebay. They are JST-XH connectors and are used in RC models:-
Lipo Balance Lead for repairing battery pack 3s JST-XH male 3-cell, 11.1V, 22AWG | eBay
You will also need a 9 pin (male) sub D-type connector.
slugworth has supplied the connection diagram.
^ I have one of those cables and it works fine.
HI DEEJAYAJ THANKS FOR YOUR REPLY I WILL ORDER ONE NOW MATE
