Results 1 to 7 of 7
Hybrid View
    Top Poster Grover2000's Avatar
    Sep 2010
    Question Help required. Multiple display output question
    Hi Apple Gurus,
    I have a Macbook which I need to output to two devices.
    Currently the Macbook outputs to a projector via Airplay and I would like to output the same signal from the Macbook to the ipad?
    Is this possible? I would prefer this configuration, but I am open to alternative solutions.
    Thanks in advance.
    Grover
    Oct 2013
    uk
    What operating system you running? you could always try:- Turn Your iPad Into An External Monitor [Video How-To] | Cult of Mac
    Oct 2013
    uk
    I can confirm that it works on Mavericks! Not the fastest but very useable for ?2.99!!!
    Oct 2013
    uk
    It also works on the iPhone, however only the one at a time!
    Sep 2010
    I have tried and downloaded I display and noticed that you can remote the MacBook.
    I don't want this feature. I only require the iPad as a display only.
    Is there an option in the settings for this?
    if there is no option then is there an alternative program
    thanks in advance
    Oct 2013
    uk
    As you said, It works as an additional display.
    However if you click on iDisplay on the titlebar and select preferences. Click on Displays and on iPad change the selection to Color LCD. This will mimic your Macbook display on the iPad
    Dec 2012
    I had used it even before Mavericks.
