Dont know if any of this is of use to you they are files I collected some time ago but have never had to try them.
Jemenyah jonas (31st August, 2020), Myfinder (10th October, 2019), stone96 (20th January, 2020)
tried them all .. seems like i need factory setting file as the updates just do nothing ... must be an internal problem ... thanks anyway .. could do with someone who has one to dump there whole system as a back up and upload that ...
hi jayja try these mate contains 3 files. ws 6906 original bin file,EU satlinink bin + upgrade exe. WS 6906 software.rar how to satlink.JPG cheers shaun
satalightmad (9th July, 2014)
I have tried mine for the first time last night and would like some assistance from someone who is familiar with this meter. I had 0.8W selected and when to the selection for 'reference satellite'. Pressed OK and the motor moved to 0.8. Tuned the dish into that position, but do I have to reselect another sat say 19E and then hit the 'reference satellite' again for it to move to that position?
Any assistance would be much appreciated as the manual does not give the finer points of actually how to use it. I expect it would be easy for a professional installer but a bit of guidance for the layman would be great.
Regards
these instructions are for "usals"
I"v never used mine to drive the motor.and use it this way.I scan channels in from an existing dish/motor,if you only have a sly dish just scan 28.2E in. then using the box put your local lat/long in and send the dish to your chossen sat disconnect the cable from the lnb and using a fly lead connect the meter up and select the sat with an active TP/channel you have sent the motor to.then you can turn the whole motor/dish assembly L/R and the dish only up/down to tune the sat in.Its a nice and easy meter to use but using it to drive a motor will flatten the battery in no time.
PS once you have your target sat tuned in correctly with usals all the other sats will fall into place automatically subject to your mounting pole being 100% plumb and the dish 100% central on the motor spigot.
hello i can't download the eu firmware. can you post the last firmware for the satlink ws 6906. thanks
Old thread, but does anyone have updated salelite-database for the 6906?
Hola, this archive is from ws -6906 ?
hello from Turkey...
is there any way to upgrade this ws-6906 with less TP list for just 4 TP include low . high vertical and horizontal diversity....
thnk frend
Does anyone have the US satellite .bin file?
Is this link still valid:
Sorry if I'm a Johnny come lately, but I acquired this old WS-6906!
Regards
