Results 1 to 4 of 4
    DK Veteran Time2Play's Avatar
    Apr 2009
    Default how to recover a wpa key from intel proset
    hey i need help to find a wpa keyy on intel proset wireless i have a friends laptop who lives down stairs from me he said i can use his router but he likes playing games so he give me his laptop and said find the key yourself is there a way to putt it iv tryed all i know
    V.I.P. Member Curious123's Avatar
    Apr 2008
    If you know what sort of a router he has then it should be quite simple as you could log onto his router and find the key. If you don't have access to his router than you will need to hack his key.
    DK Veteran on_the_jazz's Avatar
    Jul 2008
    As mr. curious said you just need access to the router. Connect with a lan cable and log on.
    I know you want to try and get the starred out key already typed in on his laptop but I have no idea where that is stored
    Trying to wirelessly hack wpa is going to be very time consuming, perhaps too time consuming if the key is long and complex.
    Mar 2008
    If you have access to his router RESET the router, think the reset button is on the back, small recessed button, use a pen or something. Default username and pass is probs admin and either 1234 or password.......google it. as someone has already said wpa not easy to crack unless its wep, different story.
