hi there some one selling a tis2000 sps dongle emulator on ta bay can any one share it or have any info on it
Please read the folowing:
Well guys as Mr ******* has explained 2009 GM vehicles onwards will only be able to be programmed via an MDI. One thing he doesn’t point out for those of you thinking of purchasing an MDI is that MDI works via Tis 2 web
Which is internet based to a factory/head office server.
If you purchase an MDI around ?3k you will then require a license Euro 3650 for 365 days or 4 Euro 1 hour, 30 Euro 1 day, 100 Euros 7 days, 300 Euros 30 days This will only open up part of the features, to be able to do SPS and security you will have to attend the GM academy training courses
TIS Class Room training; Course SVEL 61 (Class Room Training)
Tech2 WBT; Course SVEL 32b - Web based Training
Relevant to SPS and security also at a hefty cost.
Now for those of you thinking you’ve had a good run but you won’t invest in the future MDI, Tis web and courses. But you will happily carry on using your old faithful tech 2 on vehicles up to 2009 for SPS and security.
Well here’s the really, really bad news NO YOU WONT.
As the existing stock of GM Engine controllers depletes, the manufacturers such as Delphi, Siemens etc obviously have to replace them.
When these manufactures make a new replacement ECU whether it be for a 2009 Insignia or a 1999 Astra, Vectra etc the new replacement module has a new Supplier Hardware number, these Supplier hardware numbers have always been added into the TIS system database. One of the reasons why the dealers had a monthly TIS disc so they could always programme a newly manufactured controller.
Now all recently manufactured controllers have new supplier hardware numbers but the database for the supplier numbers is no longer on the TIS disc not even the final disc for SPS disc 91. All future Supplier numbers are, you guessed it on Tis2Web.
So this means that if you purchase a recently manufactured ECU for say a nine year old vectra you will not be able to SPS programme it with your tech 2.
P.S. The emulator will work using the V91 disc or earlier unless as stated the HW ID has changed on the component you are fitting, but bear in mind any update will most likely be out of date and only cause you issues later on. (the emulator only allows sps programming from discs V.91 and earlier it DOES NOT bypass Tis2Web)
ok understand that does any one know if the emulator works can it be used with the other tis disc saab ect
Depends on the emulator/creator, the one I know that does work was designed specifically for Vauxhall I'll try get hold of it's creator to see if that one works on Saab, failing that I'll ask the person who gave him the source files used to create it, or maybe he'll post here as I know he visits this board.
P.S. My guess is if the Saab TIS disc contains the calibration files then the emulator might work, but it's a big "might".
looked all over the net any one got the emulator or a clone usb stick
yes the eflay dongle should work.So much talk about whats happening with tech 2 ,usually coming from people who dont use it.I happen to use both tech 2 and tis2web,and most of what is written is in fact incorrect.I fitted and programmed a new controller a few weeks ago that was manufactured many months after the june 08 software i was using.
Joe
Do you have the saab tis disk ?
i have a disc from 2007 for saab
is it TIS 2000 and if so any chance of a copy.
Joe
my tıs 2000 sps dongle indefinitely open ok laptop pc ok there is msn address you 250$
Dont post your Email address and DONT sell stuff here, sixpack
Last edited by sixpack; 25th October, 2009 at 09:21 AM. Reason: email address removed
Here is the dongle emulator for the TIS2000
But you will need the LPT1 in your computer to work properly
if someone help me to let me know how to upload, will upload the file, i get invalid file message_
Press -Go Advanced- for manage attachments.
ct204 (23rd June, 2013), jmn (12th August, 2016), pablobonome (4th June, 2021)
Both of the files needs to be in c:windows/system32/drivers
ct204 (23rd June, 2013), Homerz (11th June, 2019), jmn (12th August, 2016), sebastian (23rd July, 2013), Sparky1974 (17th November, 2017)
