Test the crack dongle ....
crack_TIS_no_dongle_required NEW
ALBERTO_ (23rd November, 2017), artini (26th March, 2024), ciptel07 (17th October, 2016), digis99 (15th November, 2017), ilhafi (15th February, 2016), jmn (12th August, 2016), polete (26th January, 2018), Positron2200 (18th February, 2015), sauliuk (14th May, 2016), sebastian (26th September, 2013), tomxx (18th November, 2017), urcarpc (18th March, 2017), Yuri_L777 (16th February, 2016)
thank for all the posts i try em out later but i stupidly broke my leg at motocross so it a be a while before i get back down the work shop
THANKS very much for your "Pill" but ONE SERIOUS QUESTION:
Why when i try to install by pressing EXPRESS i get the message "ERROR Registry access error" even if i try custom and set it to 32 bit driver only i get the same message about the registry access error, and in under "System" part of the windows it says "Driver is not started"!!! Any GOOD idea?????
Thanks a lot....
Cheers!!!!!![]()
Does it work on GM USA models?
Thanks!
Can I use this software with a different interface other then the TECH 2 and Does this work sps crack on TIS GM USA?
I have tested dongle emulator on opel (01/2008) and saab Tis ( 01/2007) and both work perfectly installing driver first and then overwriting both files in program files/cosids/bin and have successfully updated my Tech 2 (only have 10mb pc card at this time) and carried out enable programming, not sure why its not working for you Patrian ! Are you maybe running 64 bit O/s?
I am running windows xp sp2 32bit,Keep trying Its Worth the effort to get it working.
Thanks a lot m8 about your info but listen:
BASICALLY i HAVE ORIGINAL Dongle Key and all the Equipment.....
This procedure i want it for one Friend.....
For testing, i try to use this procedure in my Lap, but once working and other ALL THE TIS2000 STUCK A LOT!!!!!
The message about driver always PRESENTING!!!!!
Anyway..... For the "Story" i using Windows XP with SP3 32Bit, OPEL TIS2000 Version 93 (8.2008) and Tech2 with 32MB Card.....
Cheers m8!!!!!![]()
what's the best hardware to buy? i wanna be able to enable cruise control and change stereo's n stuff?
Anyone have a copy of the SAAB TIS disk. Any help would be great.....thanks
