Results 1 to 8 of 8
    May 2011
    Default 2 SkyBoxs inteference?
    hello, i have 2 skyboxes one is an f3 in the living room connected to a dish pointing at 30w the other is a f5s in the bedroom connected to a dish pointing at 28.2e
    the f3 is connected wirelessly and f5s by ethernet
    when i switch both on they seem to intefer with on another, one will go scrambled for the other one to work then that one will go scrambled and the other one will work for a bit. anyone know whats going on?
    I assume you have separate LNB feed to each one.
    Do you have a good signal (watch a FTA channel) on both boxes and is it ok then?
    May 2011
    yes it's 2 seperate dishes. i will try fta channels 2moro as i cant test right now, but something else that was happening is the boxes were also rebooting by themselves at random ponts.
    Oct 2008
    If you are sharing (something that we cant talk about here,) that may be your problem why channels are scrambling
    May 2011
    Quote Originally Posted by sexysam View Post
    defo not sharing one is European one is sky.
    digicon's Avatar
    Guys please do not mention anything to do with Card Sharing, Please keep to the point at hand which is 2 receivers interfering with one another.
    My suggestion would be check in your router menu and see if they are having an IP clash as its well known that Clones share the same MAC address, Just an Idea
    If you can have both boxes on at same time whilst watching a FTA channel on both without a problem then it's likely to be something, as digicon has pointed out, that cant be discussed here.
    May 2011
    Problem no longer happens. Strange...
