hello dk
i need to adjust speed limit to a sprinter 412 1996 down to 90km/h.
its HHT diagnos. anyone now the procedure for this please?
i have never dun it before.
thank you
peter
hello dk
thank you
peter
i have change it on newer Sprinter with autocom-delphi in the past
you can change it up to 160khm
bR
hello pandokrator
i have 160 km now, but the customer like to go down to 90km/h
i will try autocom and repplay.
eyxaristw file
panagiotis
no lack with autocom, and no lack with hht.
anyone have any solution for this please?
i need speed limit for sprinter 904, down to 90km/h
anyone please!
I can help you but only if you want me to help you
All the questions should start from what car, what year, what engine is what fuel. What are the symptoms of the problem. Only then is what you know, what fault code, live data, what you have done.
i do but drivers ignore it!!![]()
pbn (31st January, 2014)
when i try to program speed limit with HHT, i get this message,
then i go to wis, but nothing! cant find anything!
searching on google, i read that the ecu has a speed limit on the eprom in pulse, but where in eprom is this pulse?
hi Pano,
DAS is avalaible ?
have you ecu number ?
bR
hello pandokrator
thank you for repplay
yes, DAS is available.
and this is a photo of the ecu.
i hope you can help me because customer come for tuning and limit,
i make the tuning, and because i cant fix the speed limit, he will not pay for the tuning!!
thank you very mach
panagiotis
For tuning and limiting to 90 km/h
U fill oright mate? Luks that customer cnovs that canot be done so gets free tuning
Remove toning and send him ****off
maybe customer need make better run time 0-90 km h
any way ,car have tachograph on dash ??
have you any dtc error ?
send me dump by pm ,maybe i can fix it ;-)
bR
hi Pano,
are you sure car have speed limit ???
if MUST add limit on mb WITHOUT this ,the solution come from VDO
best regards
