Results 1 to 7 of 7
    Oct 2013
    Manchester
    Default No Signal Fix Cable
    Hi, does anyone know how to make one of "no signal fix" cables? I know that there is a resistor or something like that in the middle of the cabling.
    Nov 2010
    Just buy on off ebay, there only about a skin diver delivered
    why do you need one?
    Sep 2008
    more than likely his lnb dont suit the skybox,very very common fault and if using the fix and moving box it might short out and blow the box.
    Hadron's Avatar
    Nov 2012
    E. London
    Quote Originally Posted by wardyuk1 View Post
    It's just 1 rectifier diode (such as a 1N4001, 1N4002 etc.). The diode is polarised with a white band, so has to be connected the right way round.
    Have a look here:-
    http://www.digital-kaos.co.uk/forums...ml#post2129360
  5. The Following User Says Thank You to Hadron For This Useful Post:
    wardyuk1 (30th January, 2014)
    Oct 2013
    Manchester
    Thanks for the replies. I don't need one. I just like to know how things are made & how they work. Thanks for the replies once again
    Apr 2012
    If you come across the problem best fix is a decent LNB
    Sep 2008
    or buy a better satbox that uses proper internal parts.
