Hi to verybody i'm trying to remove dpf in Honda Accord 2.2 I-DTEC with ecuBosch EDCD17CP06 volta 1.2 without succes, now the dpf ight is off but the car still runs on limp mode.
I uploaded the original file and one file modified by Volta and another modified by a friend
Anybody can remove dpf off my file?
Thanks a lot and regards.
dpf off file from your friend is good, switch solution.
Ecu tuning, DPF, EGR and FLAP remove
Hi again how say assitutto the switch file of my friend is good, the problem was reset values ECM/PCM with diagnostic tool for to clear memory, and now the car has got power.
Thank you mate.
there is a 3 byte switch manual solution
soplillo (7th February, 2014)
franz (7th February, 2014)
Hi, after DPF OFF on your accord Did your cruis controll still working? BR.
Inviato dal mio MI 2S utilizzando Tapatalk
