Results 1 to 9 of 9
Thread: Skybox Problem.
    Jan 2014
    Default Skybox Problem.
    I have two skybox F5S one down stairs one upstairs the one upstairs receives all channels just fine but the one down stairs will loose the signal on certain channels such as Sky Showcase thought the problem was satellite or wire I then tried switching the box down stairs for the one up stairs and using the upstairs box all the channels work fine so it seems to be something to do with the box. any ideas guys bit weird that one box gets all channels but the other doesn't even though there on the same Arial.
    P&D's Avatar
    is the channel list upto date ??
    do you have both the boxes on at the same time ??
    Hadron's Avatar
    Nov 2012
    E. London
    Quote Originally Posted by P&D View Post
    Yep. Sounds like he might need the "no signal fix".
    bez...if you noticed that you were missing channels while both boxes were turned on at the same time, try switching off the box that is working OK, & see if the non working channels re-appear on the other box.
    Jan 2014
    But how would I get both boxes to work.
    Hadron's Avatar
    Nov 2012
    E. London
    Quote Originally Posted by bez View Post
    IF your problem only exists when both boxes are on at the same time, then search Ebay for "no signal fix".
    Jan 2014
    Well I turned my box off but down stairs still doesn't get Discovery +1 Sky Showcase ect.
    Jul 2012
    I am having exactly the same problem, both boxes worked fine up until last week, whether both on at same time or only 1 on. skybox F5s & F5. Firmware & channel lists all updated.
    Mar 2012
    Like someone has said before by a no signal fix!
    Or buy a more expensive LNB!
    Hadron's Avatar
    Nov 2012
    E. London
    Quote Originally Posted by sailsy View Post
    It may still be worth trying the "no signal fix", but in all the previous cases I have read about, it only seems to work if the problem is caused by having 2 boxes on at the same time.
    They are only a few quid though, so might still be worth a try.
