Results 1 to 8 of 8
    Member tuning73's Avatar
    italy
    Default fgtech problem Error changing speed
    hi please help me!!
    my fg v53 clone reads everything in reading ok
    in writing almost all of the ECU Error changing speed
    both k -line which can equal error
    any idea or solution and appreciated
    Sep 2013
    Its bad clone, why dont you use a european clone rather than the chinese rubbish? This is what happens imagine if it kill a ECU?
    italy
    I do not think that it is so bad clone
    after repairing can not read any ECU
    but I have problem writing as described "error change speed '"
    Nov 2011
    friend and friend
    friend to ignore the previous post
    Apr 2012
    Hi, when it say error change speed, seems to be no connection with ecu, try disconect obd plug, will be same message.
    italy
    maybe I explained evil
    I managed to fix fg clone now reads all ECU k-line can bdm jtag ok test ok ( edc15 edc16 edc17 bdm jtag ecc.. perfect read write)
    on some ECU can not write edc 16u34 (id ok read ok write error change speed)
    marelli iaw 59f same error read ok write error change speed (bot mode read write ok)
    edc16c39 fiat same error read ok write error change speed
    edc16u1 id read write ok
    marelli 6jf 6f3 id read write ok
    I do not think it is hw problem if the law should also write
    possible problem with the firmware or driver?
    it does not happen to anyone in these ECU ?
    Sep 2013
    From where did you buy your clone?
    Jun 2013
    EU
    V53 sw still plenty of bugs.
