hi,
I'm trying to get the blue screen in my image and I am not able, walk to copy the source of the hydra does not compile when the image is not in the blue key blue panel, which will be someone I can give a helping![]()
hi,
Not sure exactly what you're asking???
Any additional files that are added to src, make sure you add the filenames to the Makefile.am file as well.
For any remote control functions, edit /share/tuxbox/enigma/resources/rcdm5xxx.xml after you do a 'make rebuild-flash'.
ull have to do alot to the hydra code to get it to compile with todays cvs far too many changes since they were posted![]()
but if u post any errors up we can take it a step at a time till its alled compiled![]()
failing that look for nemesis or merlin sources you may have better luck compiling them![]()
cheers
osborne82
thanks my fryends,
gave me some good tips, then I'll give reports on how everything went
I have discovered the source of nemesis but now I do not know which are the files of the blue panel, will be that someone could tell me which files and what to do?
