Hi friends
which type transponder should I use for suzuki G. vitara 2002/3, denso ECU number 33920-76JD; IMMO BOX number 33970-80G0.
what should I read to add keys on ecu "eeprom"?? on immo box i have 24C01
4d 60; 65
Thanks in advance
Hi friends
4d 60; 65
Thanks in advance
Press "THANKS" button. just one click, CHEERS
Hello friend,
Use 4C transponder.This is type 2 immobox.
A dump from immobox would certanly help...
did your sbb error "key not loaded"?
"key not loaded" mean wrong transponder usually
Definitely 24C01 badly read,confirming what ngakson2002,dump is not recognized.Also I checked your dump with editor,keys are deleted.
Hi friends
I need unsolder 24c01 to read or nor need !!??
I read it with eeprom in circuit maybe there is problem
cheers
33970-80g0 is 4d65
33970-67j0 is id46
Hi friends
I read the 24c01 out of the loop but got the same file.
Does someone could please repair the file or get yourself a pair of file to ecu and immo box.
Maybe someone cam help to add key :
Pg1 F9 Lock
pg2 00 Unlock
pg3 E41D0116 Lock
Thanks in advance.
cheers
Its been flashed with the wrong files. The 1202 number in the immo file identifies it as being for an old Vitara 1.6 16V and not a Grand Vitara. I don't have the correct files, maybe someone else can help.
