Results 1 to 9 of 9
    dave11674's Avatar
    Florida, UK
    Default help needed with 1175 slim drive pls
    hi guys
    i recently picked up a slim
    its got a 1175 drive in it
    no biggie
    i believe i have to change the drive board yes ?
    if this is the case can any1 point me in the right direction as to what i must do to be able to flash this and play my games
    can you supply a link for a good reseller of the replacement pcb's
    also is it live safe ?
    if its not live safe there is no point as this if for my son
    i have RGH chips in
    i have various tools
    maximus lizard
    and so on
    any help greatly appreciated
    dave
    Tools owned.
    AVDI commander.
    Dashfixer orig.
    Dashfixer clone.
    Fiat km tool.
    Opel km tool.
    Ford KM tool.
    Op--com colne.
    Lexia & PP clone.
    Smok PSA, volvo & ford
    If someone helps you DONT FORGET TO SAY THANKS its only polite....
    cunny's Avatar
    Jan 2009
    The Shoutbox
    Your going to have to glitch the console to obtain DVD key and FCRT.bin
    Then you just flash a replacement PCB
    Xecuter LTU2 Replacement PCB Hitachi DLN10N / Liteon DG-16D5S USA CANADA
    dave11674's Avatar
    Florida, UK
    top man cunny i thought you would come to the rescue
    is it going to be live safe tho thats teh question
    after i jtag it ill remove all traces of rgh chip and wiring and .........
    hmm wait i may just rgh its ass
    no need to do drive then is there
    dave
    Tools owned.
    AVDI commander.
    Dashfixer orig.
    Dashfixer clone.
    Fiat km tool.
    Opel km tool.
    Ford KM tool.
    Op--com colne.
    Lexia & PP clone.
    cunny's Avatar
    Jan 2009
    The Shoutbox
    Quote Originally Posted by dave11674 View Post
    dave
    No. I had 1 come to pre xmas an it was glitched by blakey on tx, did good job an boot times were fantastic.
    If you glitch you always got link to play on anyway
    An yes, all upto date fw is as live safe there is
    Sent from my GT-P5110 using Tapatalk HD
    dave11674's Avatar
    Florida, UK
    hmmm
    think ill just RGH its ass n sell it
    thanks for your pointers mate
    dave
    so basically to clear this thread up in case some1 else comes searching for info on the same topic
    you can do these drives but you need the replacement LTU board
    rgh your machine and get teh required files
    flash your replacement board with the relevant firmware
    leave RGH or remove rgh and flash back to stock and away you go
    correct me if im wrong here cunny mate
    dave
    Tools owned.
    AVDI commander.
    Dashfixer orig.
    Dashfixer clone.
    Fiat km tool.
    Opel km tool.
    Ford KM tool.
    Op--com colne.
    Lexia & PP clone.
    cunny's Avatar
    Jan 2009
    The Shoutbox
    You dont need to flash stock fw as orig pcb will have it.
    You only need nand dump an cpu key to retrieve files from nand.
    Once you have them, remove glitch, replace pcb an away you go, insert orig pcb to update dadh as normal
    If you prefer glitch, leave glitch in as usual
    You got it pretty much in a nutshell m8
    Id glitch these suckers or look at a demon (dual nand)
    dave11674's Avatar
    Florida, UK
    hi mate
    wondering if you can help me here
    same console
    im trying to glitch it
    got 2 x cr3 lites here
    ive installed both but neither is making the glitch noise from teh chip n the fan dont flutter when glitching
    any ideas ?
    im using alternate cpu reset point Dblue wire about 37cm long
    just no reset glitch xtal noise !!
    any ideas ?
    pics to follow of my install
    ignore the first chip thats stick to the motherboard
    LK2 is short
    all rest open
    set to slim and on norm
    flashed chip with 2-3 to try get me going
    dave
    Tools owned.
    AVDI commander.
    Dashfixer orig.
    Dashfixer clone.
    Fiat km tool.
    Opel km tool.
    Ford KM tool.
    Op--com colne.
    Lexia & PP clone.
    dave11674's Avatar
    Florida, UK
    its a standar V1 corona
    ive just checked under the cpu heat sink
    all tracks are there
    dave
    Tools owned.
    AVDI commander.
    Dashfixer orig.
    Dashfixer clone.
    Fiat km tool.
    Opel km tool.
    Ford KM tool.
    Op--com colne.
    Lexia & PP clone.
    dave11674's Avatar
    Florida, UK
    right mate
    ive just removed LK2 which i believe is for on board xtal and corona Mb.s
    i soldered up my own xtal like for the early mobos
    will let this try glitch for a while and se what happns
    still cant hear that xtal frequency tho when it glitches !!
    dave
    ps i put stock flash back on and it booted up just fine
    reflashed EEc back to it and tryign 4_3 timing
    Tools owned.
    AVDI commander.
    Dashfixer orig.
    Dashfixer clone.
    Fiat km tool.
    Opel km tool.
    Ford KM tool.
    Op--com colne.
    Lexia & PP clone.
