Yes it's working no problem. Just make like its in FGT2 manual. Its only pain in the ass those boot resistors
BR and good luck
BR and good luck
__________________
If You Like My Post
Please use the button on the LEFT side and the button on the RIGHT side.
Tuning, EGR, DPF, AdBlue, DTC, TVA, Speed Limit, Immo...
if friend, works perfect
read manual.
Ok thank you guys
Regards,
I need to locate the boot pin on this picture
because instruction in pdf not helping
There is no boot pin , just the connections as in manual
There is no boot pin , just the connections as in manual. Just be very careful when soldering.
friend first have to do this procedure to read id, then change and green thin wires and can read.
read manual.....
thank you my friend
Regards,
