Results 1 to 2 of 2
    Jan 2014
    Default Vu Ultimo Help Please
    My Ultimo has stopped fully loading.
    It loads until the vix background then is stable. the Display shows the circles as if it is rebooting. But it NEVER fully loads. I have tried to reflash but it will not read the usb or work through the PC with serial data cable.
    The image I installed was openvix-3.0.808-vuultimo_usb.zip .
    It is a plugin, or skin that I installed since that, that has caused this. But I changed a few setting before restart. Tried just deleting the plugins via FTP after trying all the rest but this has still not kicked the start up.
    Im struggling to find a crash log even.... With FTP working is there anyway of deleting all the reciever info then reuploading the box's basic files? or flashing from FTP?
    Im really struggling? have I bricked it? Please help my brainy people
    DOUGALMCD's Avatar
    May 2011
    Suburbia
    Easy way to uninstall plugins via the image the same way you install them via the plugin menu. I assume you got your ultimo image via vix download section. Try an older ultimo image via usb or try bh ultimo image you may need to try a different usb. Make sure you don't have anything else connected while trying to flash.
