Results 1 to 2 of 2
    DK Veteran aksimo's Avatar
    Estonia
    Default Volvo dice SETEK AB driver problem
    Hi can somebody confirm can it install on win7 64 bit my pc tells that code 10 cant start driver !
    All order soft from vida runs on normal only drivers stopping work ? maybe someone has better ideas ! D:
    DK is the best !!
    Department of factory errors.
    Estonia
    HI the problem solved ,if you have newer pc 7 64 bit you must uninstall the usb 3 drivers and soft .
    Install and use Windows XP Mode in Windows 7
    And run xp mode works good for vcm,lexia ,pp2000,vida. tested and works .
    DK is the best !!
