Results 1 to 4 of 4
    Jun 2012
    Default partner HDI siemens SID801
    hello.
    I have here a project from a partner 2.0 hdi siemenes sid801.
    siemens is new to me and do not know if I've found the maps are fine.
    but what interests me more is whether checksun okay because WinOLS does not correct me (not because it does not, with EDC15 works).
    if they can watch it appreciate it.
    leave the ols, original, and mod..:
    partner hdi siemens.rar
    excuse my bad English.
    regards
    Jun 2012
    someone could give me a look at the checksum?
    Bulgaria
    Your maps are not true.
    Driver wish is not a fuel in mg. This is throttle request factor. And this ecu has a another map for conversation throttle factor to % of pedal.
    Maps for limit.temperature in your dump are with wrong name and factor. This map are smoke limit correction by temp and atmosheric pressure. But no need to touch.
    You have to find single IQ limiter - 54mg to get more fuel. For 900 mg air mass you can inject 56 mg fuel without smoke. But you have to find rail pressure maps and limiters and rise presure with linear interpolation to get more torque.
    SOI also you can adjust for new IQ.
    Close EGR also.
    For checksum corection use winols1.7 and all will be ok
  4. The Following User Says Thank You to oem For This Useful Post:
    javiere (17th February, 2014)
    Jun 2012
    refers to a unique value of 54mg? with 0.001 factor? then 54000.
    there is only this: 3160E
    pedal maps are Nm torque? factor 0.031250? dimensions?
    is very difficult, because I do not find damos
    thank you very much for your help
