Results 1 to 14 of 14
    Jan 2011
    Default iveco daily- speed pulse pin out needed
    Hi guys some one have the number of pin for speed pulse in the dash?.
    Thanks.
    BR.
    Does this cluster has two 20 pin connectors, one black and one blue? (I cannot see it in the pics)
    If affirmative, speed pulse is in the pin 1 of blue connector
    Jan 2011
    Hi Loraier the conectors are green (32) and blue (32), thanks anyway.
    Jan 2011
    anyone;? program name for FIAT / IVECO schemes, some data however small?
    Prussia
    Quote Originally Posted by malc3469 View Post
    Thanks.
    BR.
    1996
    look under the wiper motor in the engine bay...orange wire 5517.
    no.30 green is permanent live
    red is not live when starting engine
    1997
    driver side door post over the fuse box is a black box. The signal is at pin 1 of the white 8 pin connector. The cable has the number 5517The cable colour can change. Please look for the cable number 5517.
    2000
    .Daily 2000 including model 35E11
    At the instrument cluster there are four connectors, the distance signal can be found on orange wire number 5517 in the top left connector. The RPM signal can be found in the same connector on wire number 5512
    Please help stamp out this disgusting trade.
    JUST SIGN THE PETITION .....PLEASE
    https://savedogs.soidog.org
  6. The Following 3 Users Say Thank You to TULGEYWOODMAN For This Useful Post:
    dashradio (15th February, 2014), Meat-Head (15th February, 2014), synkrotronic (5th July, 2019)
    Meat-Head's Avatar
    Tacgigraph and / or edc16
    Jan 2011
    Hi tulgeywoodman, i can test the sensor and are ok, i cant test the dash, the vehicle are many km from me so i cant se the electricpack,
    The bus have only 48 000 km (new), the company install a GPS with BUS CAN monitoring for see the speed in real time, so i think the tecnician how make the baypassing of information cut some "extra wire".
    anyway your information is good; thanks for sharing.
    Hi Meat- head I think tachograph yes, ECU i dont now.
    Thanks.
    Mar 2011
    EU
    Someone have pin out for this dash ?
  10. #9
    Meat-Head's Avatar
    Thought all the wires are green
  11. #10
    waldi1979's Avatar
    Dec 2010
    2 connectors - speed sensor signal pin 22 of Blue connector
    4 connectors - pin 1 of Blue larger connector
  12. The Following 4 Users Say Thank You to waldi1979 For This Useful Post:
    capi (5th November, 2015), Meat-Head (11th November, 2020), satesquio (8th April, 2016), synkrotronic (5th July, 2019)
  13. #11
    Meat-Head's Avatar
    Bugger forgot about this, I got some photos of tachgograph in one of these but I MUST edit the serial numbers, due to it been a stolen vechile - my imganary friend Vic see one with the keys in, so he took off in it.
    then he rather kindly pulled the tachograph out and photographed it but the dense fkuc left the serial numbers on it.
    OFF TOPIC:-
    How do you edit photo on an iShit?
  14. #12
    88diablo's Avatar
    Top right hand corner of photo
  15. The Following User Says Thank You to 88diablo For This Useful Post:
  16. #13
    Nov 2020
    Quote Originally Posted by LoRaier View Post
    Sorry to resurrect this thread from so long ago - Can you confirm for the type you describe, with 2 20-pin connectors, is Blue Pin 1 the speed pulse into the cluster? I'm looking to identify the speed pulse OUT from the cluster to the ECU / Speed limiter. I know that when I pull that 20-pin blue plug, the speedo stops working, and so does the limiter. :-)
  17. #14
    Meat-Head's Avatar
    Welcome to dk the worlds best website
    no idea on your question but as a rule the in/out will be next to each other, check with olliscope
