Results 1 to 12 of 12
    DK Veteran brad123's Avatar
    Dec 2011
    France
    Default [resolved] Problem dash iveco 2010 (eeprom 95040)
    Hi friends, I have a problem with a dash of iveco 2010 with eeprom 95040 I ​​change the miles and miles with nyo4 appear correctly on my dash flashing, blinking as with dash jumper 2007. any solution to this problem? Maybe bad corection with nyo4?
    Thank you in advance
    Dec 2011
    France
    No idea? or when a software or even a script that upa permeterait me to be on a 100% programming and ok.
    thank you
    Sep 2013
    garage
    when your millage in dash is flashing ... original value is stored also in other device in car ( ecu,bcm...etc )
  4. The Following User Says Thank You to Mr BLACK For This Useful Post:
    brad123 (2nd March, 2014)
    Dec 2011
    France
    Hi, thank you for your answer, I do not pensse another device that contains km, is because I had same problem on a dash of 3 boxer and after alignment with pps everything is back to normal, only iveco on I is not with what to do, can do their PBX?
  6. #5
    May 2010
    Poland
    When You do new model of Iveco using the same method like the old one ie. 2007 then the mileage is flashing.
    You must use better software or correct it manually.
    or post original dump here.
  7. The Following User Says Thank You to przemyslav For This Useful Post:
  8. #6
    Jun 2012
    ALGeria
    send the dump here
  9. The Following User Says Thank You to houcem80 For This Useful Post:
  10. #7
    Dec 2011
    France
    Hi, the dump is on my other pc, I get it tomorrow.
    Thank you for your help
  11. #8
    Dec 2011
    France
    iveco 2010 95040 ori.zipHello friends, sorry for the delay, here is the origin of the iveco dump (95040) 2010, if you could reprogram a 70240km is without flash would really perfect, I also stated that the vehicle and a box has automatic transmission.
  12. #9
    Dec 2011
    France
    Up up up up
  13. #10
    Dec 2011
    France
    The dash was within 90 MKM USUALLY and I wish it is 70240km without blinking course, I expect your help, this is rather urgent please.
  14. #11
    Dec 2011
    France
    help please
  15. #12
    Dec 2011
    France
    Hi friends, it is good the problem is solved, it was infact my clip of a 3M 8pin who started making whim, I welded direct eeprom on the adapter upa and everything works great, thank you for your help.
    soon
