English please....
ciao a tutti! Ho un problema che ho letto in un BDM ECU ec16c34 una citroen c4 picasso 1.6 hdi 110 cv dpf / egr off, una volta scritta modificato regolarmente ricevo la luce mil su e p0603 codice di errore del computer interno, ho cercato di scrivere il file originale ma il codice di errore rimane, inserire il file, aiuto!
English please....
" I don't need help but difficulties. The harder the better. I work the best when in trouble."
Forgive hello to everyone! I have a problem that I've read in a BDM ECU ec16c34 a citroen c4 picasso 1.6 hdi 110 bhp dpf / egr off, once written changed regularly get the mil light on and p0603 error code inside the computer, I tried to write the original file but the error code persists, place the file, help!and the attachment to the first post
clears dtc by flash, but before please review the file dpf off is wrong
Ecu tuning, DPF, EGR, LAMBDA, ADBLUE and DTC, Remove
P0603 internal control module keep alive memory(KAM) error
in this memory the ecu store all what he learn from all sensor's engine(egr dpf maf ....ect)
when you disconnect batery this memory is areased
so, you have to restore to zero all adaptations with a diagnostic interface
then drive the car on road (50km), to let the ecu store the new engine adaptations , so the KAM will not be empty
and finaly ,arease the dtc
hope it will help you
BOSCH FWA4630 @ BOSCH WBE4430 @ BOSCH TCE 4425 @ BOSCH ACS650
BOSCH VLE2140 @ BOSCH KTS550
PSA XS EVOL @ VAS @ MPPS @ MAGpro2 @ WILLEM @ UPA usb @ T300 @ AUTOCOM
THE BEST SERVICE
your file try and report, pass in PM
ivanimpalea (15th February, 2014)
thanks friend I wrote the file and the error disappeared but the car does not go over 3000 rpm.
not just remove the dtc, you must review the dpf
Exist a way to reset to 0 the learned values after DPF off?
edc16c34: good file and no problems what so ever.
Switch solution working good on this car
Hello, i have same problem.
I have write a IMMO OFF file on ecu just for go to office on road (in limp mode)
After come in office, i have write back original file but always limp mode and DCT P0603.
i have write virgin file and make all adaptation and always same error P0603
i have make DCT off from flash and always limp mode...
Please help me!!!!
problem solved by pinotec.
thanks a lot friend!!!!
HI
How repair ?
