Results 1 to 5 of 5
    Default Is there a way to protect eprom 95080 from writing?
    I have a ME7.9.9 ECU from Astra 2010 and I removed the immo from dump. It worked fine a few hours, then it coded (the client said he removed the immo box from car!) again and I confirmed that the eprom dump had been changed.
    Is there a way to prevent writing so the ECU won't update this eprom or maybe a better immo off solution?
    The ori and immo off dumps are attached.
    Romania
    Quote Originally Posted by brchip View Post
    Yes it is possible .You have to set 0x8C to status register and after that to pull down WP (write protect) to ground.
    Jul 2012
    raise pin 3 and puts it on pin 4
  4. The Following User Says Thank You to DOUGLASDL For This Useful Post:
    ioanrokos (31st March, 2021)
    Sep 2013
    garage
    for wp see 95080 datasheet
    Top Poster + metsat's Avatar
    on world
    hi,
    I have that programmer, its fine for eeproms, you can lock and unlock.
    MCUmall Electronics Inc. A low cost EPROM EEPROM Atmel PIC I2C SPI programmer online store
  7. The Following User Says Thank You to metsat For This Useful Post:
    brchip (23rd February, 2014)
