Page 2 of 2 FirstFirst 12
Results 16 to 26 of 26
  1. #16
    Nov 2015
    Quote Originally Posted by genzy01 View Post
    same problem blue lock still on and no signal, please help
    after using satlink ws-6906.zip works again. thanks josepheid503
  2. #17
    Jan 2016
    Default solved
    Quote Originally Posted by josepheid503 View Post
    For everyone that is having the same problem, the solution is very simple. I did get a "custom" firmware for the machine and did perform an upgrade.
    Now the machine is working perfectly, even better than the stock firmware.
    This is the firmware + upgrade tool, hope it will help other people in the future. Also i will try to get the original firmware and also try to share it here.
    Attachment 246250
    Best regards, J.E
    Hi just downloaded zip done the upgrade worked brilliant for my blue lock led staying on
    thanks a million
  3. #18
    Mar 2016
    in the djpbox sat there are new things like key set and blind scan
    anybody try it?
  4. The Following User Says Thank You to avn For This Useful Post:
    esaesa (4th October, 2016)
  5. #19
    Member Technophobic's Avatar
    Mar 2016
    Up North
    Quote Originally Posted by avn View Post
    anybody try it?
    Yes I have had it on my meter for about an hour. Afraid I cannot enlighten you further, I am trying to figure out how to get the menus to use the whole screen. At present it makes things quite difficult to see.
    I think I might need a magnifying lens add on.
  6. The Following User Says Thank You to Technophobic For This Useful Post:
  7. #20
    Apr 2016
    Hi dear,
    i see you are handy with the firmware,
    is there a way to get change the firmware so the Satlink will also check the normale TV signal here in Spain?
    i have see it once by a handyman also changes some things, but i realy dont know what he has do with it.
    Attachment 246250
    Best regards, J.E
  8. The Following 2 Users Say Thank You to wba For This Useful Post:
    esaesa (4th October, 2016), Sportskitlvr (13th December, 2018)
  9. #21
    Feb 2011
    I had exactly the same issue here, paid for an update from satlink themselves and my ws=6906 just had no signal, the blue lock light was permanently lit. I thought is was completely goosed. Your custom firmware has restored it back to working condition. Nice one josepheid503!
  10. The Following 3 Users Say Thank You to triggerup For This Useful Post:
    aksneo (16th December, 2016), esaesa (4th October, 2016), shooman (28th August, 2016)
  11. #22
    Dec 2016
    Please help me and me
    Can not save the list of channels when you give the device resets.
    I tried to do updates but I get this error.
    burn flash error, error address:000000
    SatLink6906
    thank you.
  12. #23
    Mar 2017
    hi Guy.. Anybody know how to solve my NEW ws-6906 the problem detection for TP 12500 v 43200 Ku Band FTA in Chinasat 11 bad low signal not locking compare with ws-6933 within 2-3 minit fast locking.. Is it problem SYSTEM of must Upgrade FIRMWARE..?
    I need for Help.. TQ Guys
  13. #24
    Jun 2017
    thanks. i solved the problem whit your firmware.
  14. #25
    Feb 2011
    I have same issue and would like to try to solve with this update, but when I try to get the software from link, I keep getting this error from the site: satlink ws-6906.zip
    Your submission could not be processed because a security token was invalid.
    If this occurred unexpectedly, please inform the administrator and describe the action you performed before you received this error.
    I have made posts so should have access to download I think.
    Any suggestion?
    /Harald
  15. #26
    Jan 2019
    Attachment 246250
    Best regards, J.E
    I can't download this... it's telling me to log in. I have already posted and should be able to download the attachments? Any ideas?
