help please...
help please...
Can someone tell me for sure if this software will clear the crash data in the airbag controller module, not just reset the airbag light but actually remove the accident history data from the module itself?
I really want to see what it can do before spending so much on the interface cable only to find that it's no better for me personally than the handheld unit (Autel Maxi-Diag FR704) ... so any advise on the differences would be really apprecated?
sorry , doesn't work
create a empty txt file in c:, rename it to build version.txt
run setup - doesn't work
run instlex3 - doesn't work
can you help , please
It will do more than any other diagnostic tool, however it is just that a diagnostic interface it won't remove/clean crash data as this is usually something dealers wish to keep on record, I think you need a more dedicated airbag resetting tool/programmer to be able to do this
replace instexe with cd pic for one from cd before 43 ore less burn again than it runs
Hi, I have a problem down the Citroen Lexia 3 CD44, normal install everything, but when I scan a model of car tells me that my turn, I could help, about the peugeot planet keygen active normal to me .. thanks for the input, but I can help Citroen Lexia 3 CD44 in order to enable active
Stick this one !
Thieves - EMU FAP original pictures
hi, i have loaded lexia 44 with no problems. but i have problems activating. i am using the pps2000 keygen but i can seem the get it to work. what should i use as the customer code? i accidently updated via the internet. will that cause me some problems. thanks
Stick this one !
Thank you for your quick reply. i am using the following info and still doesn't work,
CUSTOMER/RRDI CODE: CH0001
SOFT VERSION: LEXIA-344.60
IDENTIFIER: 1388535900
SERVER REQUEST CODE: CHANGES
I then copy the activation code across and it says "activation code is invalid (error code11)
Stick this one !
sorry i didn't mean changes. when the server request code is given to me by lexia activation screen. i input this into pps2000 keygen with the above info(previous reply) and then press "get activation code" i then copy and paste into lexia empty field. then prees enter and i get the error code.
not to sure what i am doing wrong
