Page 7 of 9 FirstFirst ... 23456789 LastLast
Results 91 to 105 of 132
  1. #91
    drakov's Avatar
    Aug 2008
    for latest versions you need dserver account info planet won't update online after version 22.17 I think so don't try or it de-activates your machine and needs re-installed v45 lexia updates just fine for now but I believe they are working on a one system for all and online updates will be blocked but we shall see, you can perform updates manually from hardrive but it takes a while, my advise is simple unless you have previous dealer experience on using this software or have lots of your own cars to test it on then don't perform updates if you do try make sure you have a BSU available as it will be needed on some vehicles
  2. #92
    I can't find a good keygen, the ones I find are infected with virusses or "Windows cannot acces bla bla, something with permisions"
  3. #93
    Default Thanks
    Quote Originally Posted by citronel View Post
    - maybe when you copy/paste code you copy more than only the code ( maybe a space or a CTRL-ENTER )
    or
    "- SOFT VERSION: LEXIA-344.60"... maybe this string it is not like it is displayed in request form or how generator expect it ?
    Thanks for the file!
  4. #94
    As I understand, RRDI is Customer Code in PPS2000? =RV0001 or FR0001. Yes or no? Could u answer me.
  5. #95
    Work it also in Lexia V.45 ?
  6. #96
    Work it also on Lexia V.45 ?
  7. #97
    Quote Originally Posted by dimoss View Post
    Not anymore. They changed all the dealer codes.
    I use these codes for already several years.
    Ronald
  8. #98
    Quote Originally Posted by cit View Post
    no this all really dealer codes with a letter.
    But all the dealers have only one license when the have 1 tool.
  9. #99
    So, may I update PPS from 22.14 to 22.22 over internet without loosing activation? Thanx!
  10. #100
    thx for this
    or
  11. #101
    Lithuania
    Why i cant dowload keygen ?
  12. #102
    Quote Originally Posted by Min2xx View Post
    because you did not wait 15 min...
  13. #103
    Hello ,
    when i try to install lexia 3 cd44 it asks me to install lexia recovery cd first .I created version.txt files in the root , but it doesn't help
    Thanks in advance
  14. #104
    Hy,
    I will try ..45 too.
    Tnx
    Mikel
  15. #105
    Default lexia installation problem
    Hi tutlev, I have the same problem, could you please post wich file you had to copy to the root directory.
    thank`s
