Page 3 of 9 FirstFirst 12345678 ... LastLast
Results 31 to 45 of 132
  1. #31
    Jul 2009
    how did you do it?
    what is the file
  2. #32
    Jun 2009
    hi tutlev1
    help me please
    "Please install the PROXIA Recovery CD before installing this version."
  3. #33
    Jun 2009
    build version.txt (blank file) in c:\ (root directory)
    then setup again...
  4. #34
    Jul 2009
    Can someone tell me for sure if this software will clear the crash data in the airbag controller module, not just reset the airbag light but actually remove the accident history data from the module itself?
    I really want to see what it can do before spending so much on the interface cable only to find that it's no better for me personally than the handheld unit (Autel Maxi-Diag FR704) ... so any advise on the differences would be really apprecated?
  5. #35
    Jul 2009
    sorry , doesn't work
    create a empty txt file in c:, rename it to build version.txt
    run setup - doesn't work
    run instlex3 - doesn't work
    can you help , please
  6. #36
    Jun 2009
    Quote Originally Posted by kakimoto33 View Post
    this is dealer diagnose software and not a CLEANER for airbag or what ever
  7. #37
    May 2009
    Quote Originally Posted by tutlev1 View Post
    fixed it now
    had to move a file to the root directiory
    found out from a russian site
    please. you can explain me?
    many thanks in the advance
  8. #38
    Jul 2009
    Quote Originally Posted by sixpack View Post
    So you think that it will not do anything more than a handheld diagnostic tool?
  9. #39
    Newbie tutlev1's Avatar
    Jun 2009
    Quote Originally Posted by *JoKeR* View Post
    then setup again...
    joker has it in this post
  10. #40
    drakov's Avatar
    Aug 2008
    It will do more than any other diagnostic tool, however it is just that a diagnostic interface it won't remove/clean crash data as this is usually something dealers wish to keep on record, I think you need a more dedicated airbag resetting tool/programmer to be able to do this
  11. #41
    Jul 2009
    Quote Originally Posted by drakov View Post
    Thank you for the information. greatly appreciated!
  12. #42
    Jul 2009
    I still can't install it...
    can someone help me, can you show the link for the original post.
  13. #43
    Jul 2009
    help please...
  14. #44
    Jul 2009
    Europe
    replace instexe with cd pic for one from cd before 43 ore less burn again than it runs
  15. #45
    Newbie fcapillo's Avatar
    Aug 2009
    Hi, I have a problem down the Citroen Lexia 3 CD44, normal install everything, but when I scan a model of car tells me that my turn, I could help, about the peugeot planet keygen active normal to me .. thanks for the input, but I can help Citroen Lexia 3 CD44 in order to enable active
