Results 1 to 4 of 4
Thread: skp-900
    Feb 2014
    Default skp-900
    is skp-900 worth to buy please let me know thanx in advance
    DK Veteran 54321's Avatar
    Feb 2010
    lots of threads already about the skp-900, use the search button
    Dec 2010
    Nottingham
    whether its worth buying or not depends on what you intend doing with it , alot of the functions still require pin code to be obtained from another source so if needing it for those models its probably not great for you .
    if just wanting ford , landrover and jag then you may be better off with skp100 as same ford landrover and jag coverage as the 900 but cheaper if wanting asian coverage then skp 200 covers same coverage but cheaper than 900 on asian models.
    its worth depends on what you expect or need to get from it , looking at its coverage alot of euro models like renault , peugeot and citroen still need you to buy pin codes , so you have to balance what you need and want against what you get , then you will know if worth it .
    Feb 2014
    thank you for you reply I will consider that
