firstly why wouldnt the go-to-x not work? if your saying the dm500s is getting 90% then the vu solo should be aswell. try sending the dish back to zero then setting usals up in the vu solo menu with your lat/long details. when you have done this your dish should track fine if the installer set your system up using usals... also your motor/dish might have moved slightly on the pole due to the very heavy winds we have had which has put the system out slightly. regards mdt
