Results 1 to 12 of 12
    MG-Brazil
    Default Please IMMO OFF for Toyota Hilux 3.0L D4D manual 2011 RH86=93c86
    Hi, good morning ! I have a Toyota Hilux 3.0L D4D 2011 with eeprom RH86 = 93c86 ( 16 bits ) and it's with immo on. ECU DENSO 89661-0KT90 Can some one decode or immo off this file for me ? Link for ORI file TOYOTA_Hilux_3.0L_D4D_DENSO_ECU_89661-0KT90_ORI_Immo-ON_CRC_5496_EE_93c86.rar => Download TOYOTA_Hilux_3.0L_D4D_DENSO_ECU_89661-0KT90_ORI_Immo-ON_CRC_5496_EE_93c86.rar from Sendspace.com - send big files the easy way Many thanks Kennedy !
  2. The Following User Says Thank You to kennedy-afn For This Useful Post:
    redsuns (2nd January, 2020)
  3. #2
    achaccha's Avatar
    Nov 2010
    Disconnect immo write this new file "immo off" in the eeprom.
    regards
  4. The Following 24 Users Say Thank You to achaccha For This Useful Post:
    abdonete (1st January, 2020), andresmineitor (24th February, 2020), arvedo (19th February, 2014), chickyjang (2nd December, 2021), digikeys (12th July, 2019), diosnel (31st July, 2022), INFINITY13 (12th January, 2017), JJ77 (30th November, 2018), jolidj (22nd August, 2017), kaathanes (29th September, 2017), luisblas (20th April, 2017), mahmoudsaq (13th January, 2016), mauan diag (24th August, 2015), mossa19 (10th December, 2016), mrmarkus (15th July, 2017), Nols2 (5th October, 2023), redsuns (2nd January, 2020), sameja (30th May, 2017), Sigitas1989 (25th February, 2018), tellfaia (20th September, 2021), viethungspkt (7th July, 2023)
  5. #3
    DK Veteran lashkar97's Avatar
    Jan 2012
    Indonesia
    Quote Originally Posted by kennedy-afn View Post
    check the file of achaccha if its not work then i will tri
  6. #4
    MG-Brazil
    Default Problem solved !
    Hi ! Problem solved with a file of Member ! Many thanks !
  7. The Following 3 Users Say Thank You to kennedy-afn For This Useful Post:
    mauan diag (24th August, 2015), redsuns (2nd January, 2020), zziad (19th February, 2014)
  8. #5
    m93c86hilux.rarthat same problem
  9. #6
    achaccha's Avatar
    Nov 2010
    your file off
    a hug
  10. The Following 5 Users Say Thank You to achaccha For This Useful Post:
    diosnel (29th July, 2022), jolidj (22nd August, 2017), MARIKO (27th September, 2017), Rmonlpz (15th February, 2019), sameja (30th May, 2017)
  11. #7
    Apr 2013
    rav4 imm 93c86.zipHi, I need help with immo off for RAV4 2009, can you help me please?
  12. #8
    Oct 2015
    gaborone botswana
    ordwill upload file with no passw
  13. #9
    Nov 2011
    Germany, K?ln
    Default Please immo off Hilux 3,0 D4D manual 2010 RH86
    Hello
    i need immo off please
    Engine ecu eeprom RH86
  14. The Following User Says Thank You to bratannrw For This Useful Post:
    autopresent (22nd August, 2017)
  15. #10
    Member texasmeat's Avatar
    May 2012
    Need an immo off for 89661-0KN60 (file attached) Many thanks.
  16. #11
    Newbie Sigitas1989's Avatar
    Nov 2017
    Sandnes, Norway
    Guys what you can say about 2007 diesel HIACE? its the one with separate imo box can the immo off be done?
    ECU is 89661-26c61. maybr anybody has dumps with immo off?
    Thanks in advance!
  17. #12
    Jan 2018
    Panamá
    hi what do you mean by disconnecting immo?
