Here is an original file
Thanks for file. I will try and report next days.
I try this file. The car start but there is error and can not be clear with vag. Error description is END of OUTPUT ?!?!?! 00-00
This error cause the MIL lamp on?
I think it's normal to have this fault code... actually it's not a fault code, simply your VAG tells, "there is no fault"...
bobolin4o is right
When you Make the egr without software, then can be give by vag com a fault code. You can swith the EGR off for 85% with vagcom. then CAT remove + remap. Believe me, you car run as 150hp!!
Thanks all for answers.
My EGR is mehanicly close because I have problems with him. I don't need power. I just need original file only with EGR off.
