No, not possible.
No, not possible.
Fec001 (25th February, 2014)
Thanks Zmann. Erased original eprom write, mod and car runs fine. But not exactly how I want. There is no smoke (or just some).
I think something limiting the IQ but somke limiter, TL and DW are modded. If someone knows this type of ECU, please check my mod.
Car is Audi 80 1.9 tdi 90HP MY 92
Hi, where is your ori file
Did you made only one eprom? in the other you have same maps, check it.
does you rise the voltage pump ?!
My work is my life ART TECH GARAGE
Yes pump voltage raised, in the other eprom only turbo maps, totally different content. I'll upload ori dumps
EDIT: Dumps uploaded
Have you achieved the desired values (IQ) in VCDS?
Edit: I think, you modified DW wrong...
Cheers!
Fec001 (5th March, 2014)
I didn't check the desired IQ with diag yet. Next week I'll get the car not only the ECU and can try it.
You are right, I marked off DW wrong 07316. can you show me map properties of yours???
No problem...
The map is right, but the axises must be mirrored.
Cheers!
Thank you!
That is the problem for sure. I'll try
I wish you victory!
Regards!
All maps are mirrored, on the one sometimes on the both axes. I made this ecu but it was long time ago.
