can someone help vmax is 141km/h and i want to change
i want to change the speed limiter for the ecu 0261200412 with memory 27c010 and not 27c256.
from titanium data is
Bosch
0261200412
1267358584
i have a good tunning file but not have the adress to change the speed limiter from 140 .
here is the tunnig file if someone has done it or have other way to do it .
open damos and see it . ore open file with ecm with e34 driver.
ALL TUNING.
THE BEST OR NOTHING. THANKS + REPUTATION .
Isn't this the engine with the VMX "v max" module?
This is what limits speed-
Steuerger?t VMX F?R BMW E34 M5 3 8 13185800 "Kostenloser Versand" | eBay
yes it is ,as far as i know it has this module
in the throttle there is not any motor to disconnect only thr sensor exists . i found the rpm limiter in he file and is in adress c822-c823 /hex to dec /4=rm limiter
does anyone has found the vmax speed which is 141km/h
Hello.
The Speed limiter is nowhere near the 140km/h! It sits at 270km/h! If it stops earlier you have electrical probems with the sensors. Most likely a missing speed Signal from ABS System. Check fr errors and remove mistakes from tuningfile fist. Talk to your tuner.
greetings
i do not think it has a abs system ,it has a spped sensor that probably goes to instrunment panel and probably in the ecu .
so the limit becomes in the ecu at the moment that not exist throttle motor .
i have found a tunning file and use it the car goes better but the speed limit is the same .those speed limit exist in usa for not ruuning more than the normal speed it allowed.
the flash is 1024 dp and it cannot reprogrammed from the diagnostic . maybe the ecu has a small memory . i do not search .
how i can remove the spped limit from this car ?
no motor in throttle to disconnect, no flash program th check ,
