I have big problem with this radio. Can You help me read memory in this radio. I have carprog orf full and I can't read 24c32 in this radio. Do you have any idea why ?
Anyone have schema for upa ? thanks for help M
remove eprom and try
but where is it ??
Can You help me with something pictures ?
Maybe memory in FIS modul?I guess this is blaupunkt navigation MCD.
Yes this is Blaupunkt MCD and memory is in fis 24c32. How Can I read it ? please help
follow instruction from carprog
it is very easy
carprog is bad programmer
use other tool to read
I don't understand You... I please for some kind of scheme. Carprog don't work on this radio. Anyone have pictures or scheme where is this memory to read ? Thanks for help
ok I will done this radio with carprog - ground from a4 adapter must be connected. Schema from carprog is uncomplete. It is another in this radio I can't to fill in it . After entering the code I can not accept it. Sam the SET operates at 100 percent. What could be causing this behavior? Thanks
