Results 1 to 8 of 8
    Default ***HELP SUPERBOX SCREMBLED CHANNELS ***
    Has anyone got any idea? I have a super box 3, and have the update firmware (8.04e December 08)
    I went to watch the England match today 6 June 09 and setanta was scrambled, I did a reset and deleted all the channels and let the box search again. I switch on the EMU and still most the channels are scrambled.
    Any ideas anyone??????????
    Top Poster mark36's Avatar
    Feb 2009
    You did most of it right by what your saying.I guess by reset you mean a full factory reset?Two things did you press the default key after reset then turn EMU on then exit out and go to s*y sports 1 and let it go through the updating process
    many thanks for that, its worked but missing about a few movies channels.
    It found 317 channels, I know it normally finds 333 channels. So i did it agian & this time it founf 325 channels, is it a takes of keeping searching untill the full list appears
    i just did a full rescan of channels got the 333 channels but missing sky movies premier & premier 1. how do i get those back
    Sep 2008
    are u scanning thru splitters? if so remove and factory reset and autoscan ur provider and emu to on.
    sorry to be naive but whats splitters. i have the cable lead straight into the box
    aftermath's Avatar
    Mar 2008
    Quote Originally Posted by jusandjan View Post
    a splitter has 1 input and more than 1 output, so you feen comes in and connects to the input, and the outputs can be used for more than one device.
    search ebay for cable splitter and you will see what they look like
    stockport
    you could try a different provider. i use t/pest or xnthell and get different hannels sometimes but all major ones are on both. also goto 999 and prees up on remote, lost channels might be there...ynwa
