Page 1 of 3 123 LastLast
Results 1 to 15 of 32
    Default W203 steering angle sensor problem
    When I changed the battery on w203, recieve fault message on the board display - ESP not available. I erased the fault, after that erased and zero point offset component N49 (Steering angle sensor) and component B24/15 (Rotary speed and lateral accelaration sensor) and nothing. After 50m driving again receive the error fault. Then I changed angle sensor with other (second hand) and all operation again repeat, but with the same result. Please help me, How to disable this fault?
    P.S. I tried and with road test, again without results.
    Aug 2011
    Spalding
    When the wheels are straight ahead what does live data tell?
    What degree is it showing?
  3. The Following User Says Thank You to MJRVR For This Useful Post:
    mbsupport (4th March, 2014)
    When I erase the faults, in live data when the wheels are straight are 0 degree. When I move the steering wheel then degrees are from 500 to -500, but when I go to drive about 50 m, then the degrees are blocked and I recieve fault on ESP
    Aug 2011
    Spalding
    Maybe if you can get one cheap try a secondhand SAS, easy to remove as done one last week.
  6. The Following User Says Thank You to MJRVR For This Useful Post:
    I tried with second hand SAS, but problem is the same
  8. #6
    smayer's Avatar
    Jan 2012
    Just star engine and turn steering wheel all righ all left and return to center.
  9. #7
    ecumasters's Avatar
    Feb 2014
    Quote Originally Posted by smayer View Post
    you wrong!!!!!!!
    it easy. see actual value on das. Swivel stering angle sensor and find the point of 0 degrees
  10. The Following User Says Thank You to ecumasters For This Useful Post:
  11. #8
    smayer's Avatar
    Jan 2012
    Quote Originally Posted by ecumasters View Post
    you wrong!!!!!!!
    Maybe i?m wrong, you are a master i?m just a newbie..... I never see a Mercedes car in my live, just trying guess.
  12. The Following User Says Thank You to smayer For This Useful Post:
  13. #9
    That was the first which I tried..to turn steering wheel all right all left and return to center. But without success
    When steering wheel are center they on DAS the degrees are 0 and have not default, but when I go to driving, then I recieve the fault and degrees on actual values blocking. I recieve and fault for the Run flat indicator, not available. When I look actual value of lateral accelaration sensor I see that the degrees are variables (0,3-0,5) without start the engine, only on ignition? Is that supposed to be? Because now I doubt in this lateral accelaration sensor.
  14. #10
    workshop
    go to developer,reset 0 point
  15. The Following User Says Thank You to mercis For This Useful Post:
  16. #11
    I tried with reset 0 point. Without result.
  17. #12
    workshop
    have you eis with 908 or912chip?
  18. The Following User Says Thank You to mercis For This Useful Post:
  19. #13
    Aug 2011
    Spalding
    Quote Originally Posted by Grozdanov View Post
    Dont take this wrong but out of interest GROZDANOV why do you never thank any members that try to help you?
    Is it possible you may get more help if you thanked someone now and then?
  20. The Following User Says Thank You to MJRVR For This Useful Post:
  21. #14
    I don't understand you, sorry. That I have second hand EIS with 908 or 912 chip? Or what is the EIS on this W203?
  22. #15
    Really every post in this forum help me to learn new and new things. And for my problem every post help me little or much. Thank you
