Anyone have this tool does it work? Pros and Cons please. Also a few questions
1 is it standalone or does it have to be connected to a computer?
2. do you scan for key data with the probe or with a chip?
I see it has a selection between the 2 different methods of cloners for when one does not work (good).
Price dropped to 250 to 360. (good)
Chips have to be set up for it, chinese are charging only 4 dollars compaired to 9 for the tpx clone chip. think password is set on transponder as a security/locked selling feature for them. (bad/good buy alot of chips up front just in case you can not get latter on you can always clone them to a virgin transponder 0nly a dollar fifty more US than a regular 7936 transponder)
Friend has one I play with it when having time. Have a 993with 36 cloner box and 994 legit clone 36 cloners came out month after buying my 994.
davidobd2 (2nd March, 2014)
I want to know more about this Tool too. Look great standalone and good price.
Which type of chip use to clone (cn3,tpx4,...)?.
Any guy with this tool, will be very helpful.
Uses a modded china chip but is selling for only 4 bucks? Buy the copier and 100 chips and you still have a cloner with chips at 8 buck a peice or less.
Big question is does it really work and does it work on all 46 type keys? Will it copy chrysler remote and mitibushi remote keys (not the remote part) but make a key to start the car?
Carsung 468 320% and chips 4 bucks when CN# are 10 bucks?
Can select between JMA's cloning system and CN900 if one does not work try other. CN900 has trouble with chrysler.
davidobd2 (3rd March, 2014)
Someone posted video on utube using probe from video it looks like its touch screen I could not see what powers it but it appeared to be working standalone it was hard to tell video was in chinese so I did not understand what was being said. It was doing some kind of car not in america and he did not need to turn it on to get a read he just put key in ignition so maybe its like toyota in that it starts to read chip when key is put in lock. Wonder what powers this thing.
Any experience with Renaults and PSA cars?
No sorry not in USA.
This was on a Peugeot 206. (PSA).
It has a selection for english,and at top left you can select between the way trs5000 does and the cn900 machine and it is stand alone everything inside. The one selector does chrysler after crypto is changed so it should do renault. I only had 2 hours to play with one. The transponders only program once for the id number of the chip. The chips are only a dollar more than legit 7936's. The chips are most likely cheap because they do not need the circuit to log the keyways 3 to 5 times. I would not trust it to work 100 percent on keys that change crypto. I know it works on crysler but do not know about the variables and percentage. There is a reason they put 2 different types of copying into the device. It also displays the crypto code a major plus info people have been trying to keep from the public. You can write down hondas nissans crysler factor cryptos etc without having to log the write to keys.
Thank you 912secured for taking the time to check this out. What type cars change the crypto as you called it that maybe a problem?
Keys that are not reusable, the immo system changes the crypto to that car only. Ie keys that people are unlocking change crypto.
