Results 1 to 4 of 4
    Default w220 EZS No Terminal 50
    Can someone please help with this EZS 2155450608 i am trying to repair,
    Intermittently the vehicle will not crank, if you turn the key quickly it cranks, slowly then no crank, I have dismantled the EZS and cleaned the optical sensor as there seems to be no contact switch for terminal 50 just a optical sensor input, I can't get terminal 50 output on the bench as i assume it needs the esm to be connected ? is this correct ?
    Any ideas would be greatly appreciated.
    Juz
    puiu's Avatar
    Timisoara
    Bad data in ECU ,forget EZS ... make ECU virgin and adapt with Star, or if is diesel , make it auto sync,
    job done
    good luck
    puiu
    edit - i see now is 220 itought is 210 ,can be other things.. sorry
  3. The Following User Says Thank You to puiu For This Useful Post:
    juzzac (6th March, 2014)
    Thanks Puiu,
    do you know if i need the esm connected to get terminal 50 on the bench ?
    Juz
    puiu's Avatar
    Timisoara
    not shure,but i think you need esm too
    puiu
