Page 1 of 2 12 LastLast
Results 1 to 15 of 20
    Nov 2013
    Varna
    Default erorr conecting j-link TMS470R1VF288
    Hello i have big problem on connect to TMS470R1VF288 FORD 6000 CD use j-link clone ,and erorr found ...
    audiopoint's Avatar
    Mar 2011
    MACEDONIA
    Nov 2013
    Varna
    thanks friend,i have schematic .....
    Jan 2012
    Europe
    Try connetions other radio end other computer
    Dunker's Avatar
    Yorkshire
    Make sure your init sequence is correct and in your picture you don't have the WDT marked - are you earthing it?
    V Series TMS470 / EEPROM data - encryption / decryption, totally pwned.
    IEC 62056-21 - new discussion: sonsivri.to/forum/index.php?topic=60412.0
    Nov 2013
    Varna
    This radio was in he walked by someone else without knowing that if there...... try on other pc and not worked...
    Nov 2010
    Pin 25 (AWD) TMS470 connect to GND.
    Nov 2013
    Varna
    yes friend ..pin 25 to GND ..and not worked same error ... Dunker i connect AWR pin to GND and not worked...
    Jan 2012
    Europe
    You tested other Ford radio?
    Nov 2013
    Varna
    not have other radio ...
  11. #11
    Mar 2010
    connected ok projected bad
  12. #12
    Dunker's Avatar
    Yorkshire
    You have loaded the TMS470R1VF288 project file and not just selected the processor from the drop down list?
  13. #13
    Nov 2013
    Varna
    I selected yes and still not working ..I will try again tomorrow. This is same my problem and not solved .. link http://www.digital-kaos.co.uk/forums...-errors-99614/
  14. #14
    Dunker's Avatar
    Yorkshire
    It can be a pain in the arse reading TMS470 in circuit inside a Ford radio. You can have problems for ages and start doubting yourself. Then, eventually, it just starts to work and stays working. It is very strange. When using J-Mem, I sometimes have to connect using J-Flash and then immediately disconnect before firing up J-Mem and then it works. Keep at it and you will get there. Maybe scope the connections to see if you have good waveforms (although, I have never had bad waveforms when I have struggled to connect).
  15. #15
    Nov 2013
    Varna
    solved friend i use other j link !!my j link is the problem ... thanks for help!!
