nobody knows?
nobody knows?
Ok, then repair your ecu,not easy job...work with alusol for joints
anyone knows how to clone this ecu with carprog?
With CarProg you can read and reset the PIN code.
With OP-Com you can synchronise Immo and ECU.
With Global TIS you must flash the ECU with propper SW.
That's in short...
zevi36 (21st March, 2014)
thanks, I just synchronise and all is ok, the engine star and egr problem dissapear, but now the air conditioner don?t work and P1540 is in memory, with old one there is no problem with air conditioner. Maybe this ecu have this problem or could be a programation problem, What do you think?
I copy the flash memory of the old ecu in the new one and now all problems are desappear, so the air conditioner problem was in the configuration of the new ecu.
Thanks a lot for every one who help me
