New UPA-USB Version : v2.2.4.6 - download in Tool and Supportsite.
UPDATE NOW FOR ORIGINAL
Zmann (8th September, 2021)
Hi friends, i check now and no update...
edit: must go to elrasoft web site and update 2.2.5.5 available...
sorry for my mistake !
The thanks button does not burn, you can press it without any risk !
mexanico1971 (8th September, 2021)
Probably you have China.
STILL THIS VERSION
WAIT ELASOFE UPDATE
CAN CHECK FOR UPDATE IN HELP MENU
V2.2.5.5 22-FEB-2021
New Scripts functions:
function EraseDevice: boolean;
function ChipEraseDevice: boolean;
function ClickButton( AIntBtnName: String): boolean;
function SetSecurityBytesEx(SecBytes: string; AHideCtrl: boolean): boolean;
Add RH850 Mask erased sectors with a number 0-255 /menu: device/settings Mask Erased Sectors Byte
Add V850 more oscillator frequencies: 5MHz, 12MHz, 20MHz, 24MHz
Fixed 9s12 Oscillator = auto bug
mexanico1971 (12th September, 2021)
Hi folks,
I've been trying to read the EEE area of 9S12XEG128MAL (2M53J) but i get an unstable data.
I am using the latest version of my original UUPROG-S.
I can read all other areas of memory with no problem, but only the Emulated EE is not stable.
Each time i do verify it has hundreds of differences.
Is there something wrong with my UUPROG-S ?
Please advise, because i tried everything:
slower oscilator
different voltages
internal/external supply
What else can i do ?
Hi!
Don't read XC2336A-72F
UUSP-S Connected, HS Mode
Device ID: 0017E083
Device not Respond
Reading: 1 Errors Found Device: XC2336A-72F Range: 0 - FFFF
Another tools read it ok . On same wire
What's wrong? Penko dont respond now![]()
I try win 7; win xp
It is unfortunately a one man show uuprog. Penko sells develops and sort out the issues.
There has been a lost of interest from people using it.
Also the chinese version have not been developed much further.
The software developed on upa 1.3 usually doesnt work on the uuprog. kind of frustrating to use
I do not have and never have had problems with upa
upa works very well on everything you have there to read
but also the programmer doesn't solder or know the read bridges by himself
maybe there will come a tool that does this by artificial intelligence
