Yes maybe but:
How many time need wait?
How much for put car on tow truck?
How much for rent a car during all this time?
Its why we have work.... Even if our price is expensive We CAN DO IT IN FEW HOURS AND ON PLACE.
With tapatalk
Yes maybe but:
With tapatalk
I know. But I don?t need now two this inteface.
So, I have next question about UPA-S.
I today try read MC68HC05B06 PLCC52 ISP. Usually with the old version I read without problem.
But now with new UPA-S I have 997 system error.
And HW test is completly failed.
Try change two USB cables, change power supply from USB to External power.
Have anybody the same problem?
When I try read secured V850 NEC I have only security message.
But now I have this message.
Who please help to me.
I sent email to Penko and he write to me: Add power, chage USB cable.
But all without success. :-(
Many thanks
Matias
Maby solved. I test it tomorrow.
I have instaled bad version of usb driver.
Now is hw test ok.
Solved. Interface work good.
hello I read EZS module is made in TEMIC Mercedes sprinter vv crafter
data are stored in processor Motorola MC9S12DT256 - mask 0L01Y - QFP80
processor are secured !!!! please tell what type of I pick in the uuprog-s
Hi Arthur, today I try to read a CAS2 with 100nf using Rosfar 260 PDF , it bypass secured but after that it say 1 error in reading, I use external power, uncheck the error verify box but nothing,
This cas is different to Mario's example .
At the end I must do with xprog because costumer was waiting!
Do you check it before?
Ivan
Enviado desde mi SM-N910C mediante Tapatalk
THANKS+REPUTATION
Hi I know, but on these days my R260 dead, I have not choice, but I am using xprog 5.51 without trouble.
Ivan
THANKS+REPUTATION
i ordered a upa usb for elrasoft today want to read infineon chips on airbag modules what else do i need to have to be able to do this any help it a big help thanks
What ecu model. I will give you picture with pinout if i can
With tapatalk
Attachment 366166
chip reads sah xc2361a-56f80l34 infineonAttachment 366167
mazda cx5 2014 using upa
Can anyone confirm that UPA-S is able to read the full flash, not just EEPROM, from upd78f0948/upd78f0949?
I have tried with old clone but just get 256 bytes repeated across the 60kb.
Nope. Just eeprom by me to. And flash option is greyed out anyways. The option where it reads somethin repeated is memory map
Sent from my SM-N9208 using Tapatalk
jcop31 (27th March, 2016)
Thanks, elrasoft site wasn't clear on it at all, although maybe different for ROM 780948.
Are any tools able to read, and write, flash of 78f0948? NEC docs I found don't really detail protocol, just refer to their Flashpro tool for programming.
