Results 1 to 4 of 4
    ishvedoff's Avatar
    Belarus Gomel
    Post ESP MK25A XT coding
    If you need to replace ESP control module from donor, or change options, you must insert your VIN in coding string.
    VCDS can't do this automaticly in this type of ESP.
    So i make this tutorial how to make it manually.
    For example.
    ESP coding is:
    108724AD09A6089824A690767A6416
    And VIN is:
    WV2ZZZ7HZAH123456
    In ESP coding used 5 last digits of VIN (2,3,4,5,6)
    They located in 6,8,10,12,14 bytes of coding string:
    byte 6 = A6
    byte 8 = 98
    byte 10 = A6
    byte 12 = 76
    byte 14 = 64
    For convert this bytes to digits of VIN and back, used this table:
    VIN#13 VIN#14 VIN#15 VIN#16 VIN#17
    0 - A4 0 - 95 0 - A2 0 - 71 0 - 5E
    1 - A5 1 - 96 1 - A3 1 - 72 1 - 5F
    2 - A6 2 - 97 2 - A4 2 - 73 2 - 60
    3 - A7 3 - 98 3 - A5 3 - 74 3 - 61
    4 - A8 4 - 99 4 - A6 4 - 75 4 - 62
    5 - A9 5 - 9A 5 - A7 5 - 76 5 - 63
    6 - AA 6 - 9B 6 - A8 6 - 77 6 - 64
    7 - AB 7 - 9C 7 - A9 7 - 78 7 - 65
    8 - AC 8 - 9D 8 - AA 8 - 79 8 - 66
    9 - AD 9 - 9E 9 - AB 9 - 7A 9 - 67
  2. The Following 15 Users Say Thank You to ishvedoff For This Useful Post:
    andrzejk (9th May, 2014), auto coding (21st August, 2017), bani (21st March, 2014), bearheroes (11th June, 2020), Carsoft2003 (3rd February, 2018), epicsabi (18th December, 2017), firestator (22nd November, 2014), jirkamarketa (23rd October, 2019), marek_kwk (23rd May, 2017), nedved59 (22nd June, 2014), rafal (22nd August, 2022), rafkazzz (26th September, 2018), SirLSD (26th December, 2018), spotsurf29 (18th May, 2021), wokounek (2nd October, 2015)
  3. #2
    Mar 2012
    Default code rejected
    Quote Originally Posted by ishvedoff View Post
    For example.
    ESP coding is:
    And VIN is:
    WV2ZZZ7HZAH123456
    byte 6 = A6
    byte 8 = 98
    byte 10 = A6
    byte 12 = 76
    byte 14 = 64
    Hello
    if i change the code it will not be accepted what do i do wrong
    can you help me please
    do i have to login to change the code
    regards chris
    Nov 2021
    very nice, for a better understanding
    exemple: WV2ZZZ7HZAH1 2 3 4 5 6
    Byte 0 1 2 3 4 5 (6) 7 (8) 9 (10) 11 (12) 13 (14)
    Code 10 87 24 AD 09 A6 08 98 24 A6 90 76 7A 64 16
    VIN last 5 digits 2 3 4 5 6
    from table VIN# A6 98 A5 76 64
    what about disc size , start-stop , gear, TPMS etc.
    rafal's Avatar
    UK - PL
    this unit doesn't care about disc size etc
    need help
    now my goal is to buy xp-005
    who will help?
