In the manual of the 37/38 page shows your Motorola. Not remove it from the board. Soldering four wires as indicated in the manual!
upa-usb-ecu-programmer-user-manual.rar
take care of vcc a n a l o g and digital
com cable to the main unit to cut up 37.38 to solder on the page likeİ?erik.jpegMain-Board-V1-2-Serial-Programmer-UUSP-UPA-USB-UPAUSB-UPA-USB-.jpg alright?
I have read and MC to solder cables and bckgrnd low error and lift the bkgd pin same problem.lift the reset pin same problem
Now i remenber that i had a similar issue, and UPA didnt solve my problem
and after talking with a friend, he reported that same problem.
I solved this using carprog (ori) and feeding both vcc
if you have carprog you can test
idont have a carprog
Have you tried lifting only VDD and RESET from the PCB?
I have read some 9s12 MPUs this way.
Also you may need to change oscillator to 4000 or 6000. Sometimes it doesn't work when it is on Auto.
how to conect upa to mc9s12dg128
