hello mates i have a problem here , i need reset these two dumps from lexus 570 JTJHY00W0F4179705 03/2015 middle east
car came to shop with all key lost situation now i make key with tango i have ignition but no crank and immo flash light blink i tried with tango dump editor to check sync says synch code error so i synched now car crank but no start , i tried 45 min procedure maybe also synch ecu but still nno hope always crank no start but no more immo light ... now please i doubt that smartkey unit dump is corrupted somehow
smart number :89990-60304 ibox number : 89784-60090 THANKS in advance
no dtc
Sent from my SM-G950F using Tapatalk
you confirme that files are ok ?
No dtc and no immo light? The car cranks. Check mechanical problem. It be the fuel pump. And also try to sync id code with ecu with tango. And then use techstream to sync id code and steering lock by ovd on smart key special function. I had a situation like that. And it was the sync between steering lock and id code. Used tango to sync but still problem was there. And then i used techstream to sync by obd and the car started fine. Obdstar tools also sync id code and steering lock by obd
I have a 2001 Toyota Celsior - all master keys lost. I tried to reset the smart ecu but I cannot.
Are there any businesses that will reset a smart ecu?
pls i need help to reset data for tacoma 2016 89990-04020
i got parado 2018 AKL with smartkey box 89990-60430its new type smart box.so all programmers fails to pull data.aslo cant read by eeprom as it is not supported yet by any device .
So someone told me only option is to buy virgin immo from dealer and program.Now i buy new smart key box from dealer.
my question is how i can program and synchro with id code box. Need tested answer who have done ..
Thanks in Advance
toyota 89990-0d030 with 95160 eprom inside. does any one have a virgin file or can add a new key to file . the smart key is id46
regards
2009 Toyota Camry ALL Key Lost
i need set of file for smart unit ,id box and esl
car came without keys and someone tempered with the original files
key type is 94 and i need set of files to make key with Tango
thanks in advance
Hi..I do have a same year model Toyota Aqua Car. I have some problem to start my car since I have changed ID-Box and Smartkey Control unit. if you solved your problem, would you please share the Aqua virgin dump file with me? M y email is sinkoha@yahoo.com. thank you so much for your help.
Toyota Yaris III immo
Help lose lost keys,
what is the layout marked in red, what to read with this programmer
I have to reset the virgin
Attachment 635320
what is the processor ??? 12850 1436KM41L
