Page 105 of 125 FirstFirst ... 55595100101102103104105106107108109110115 ... LastLast
Results 1,561 to 1,575 of 1871
  1. #1561
    Jul 2015
    Quote Originally Posted by death9891 View Post
    Toyota Yaris III immo
    Help lose lost keys,
    what is the layout marked in red, what to read with this programmer
    I have to reset the virgin
    Attachment 635320
    Year of your Yaris?
    Sent from my HT70 using Tapatalk
    Always show appreciation to ur helper NO + THANKS = NO HELP
  2. #1562
    death9891's Avatar
    E.U.
    Hello 2015r immo H mcu 12850 1436KM41L mask LQFP 48
    mcu 12850 1436KM41L = nec? renesas?
    or maybe immo off for yaris 1.0 petrol 2015
    edc bosch 0 261 S09 657
  3. #1563
    Jun 2009
    Default RAV4 dont start
    Hy
    i have problm in RAV4 2008 , car cranking but dont start, car with smart key i must put key in start stop botton to do ignition on and crank car
    by diagnostic i can see immobiliser system unset
    please help me
    attached immobox and ECU originls files
  4. #1564
    Aug 2019
    Hello I have a 2014 Toyota aqua that was flooded. All the ecu were damaged and I have replaced them with ecu with same part number but they all came from different cars. I replaced power control management, smart key with a key, srs air bag ecu and main body and fuse box. Right now the car locks and unlocks and can turn on ignition but it would not put car in "ready". I have tech stream cable I tried programing new key but I learned that to program a new key you need one working key. I was reading post online It seems I would have to program smart key ecu as if I had all keys lost, not keys. Please can I have some advice on how to get it to start. Any tool I would need to buy.
  5. #1565
    Quote Originally Posted by CyrexZ3 View Post
    Id Code Module need to be replaced too
    Enviado desde mi Redmi Note 4 mediante Tapatalk
  6. #1566
    Mar 2016
    Hello. I figured to post to this thread rather than a new one. I have a 2011 USA Prius with all keys lost. Techstream and Autokent's seed key generator fail to marry a new factory key. I am definitely not a locksmith and do not have various programmers in that regard. I can read and write eeprom dumps just fine. I am trying to understand the details of virginizing the smart key module (or other modules?) in order to add this key. Right now the Prius is non operational, power button does nothing, and I assume has timed out the immobilizer so that Techstream cannot communicate with ECU. Any advice is greatly appreciated. I have attached a photo of the Smart Key module, which appears to have a 93c86 on the board marked IC003. Thank you.
    PS: I have attached dump file from 93c86 eeprom. I opened the transmission control module and found RH56 eeprom, but when read is all 0000. I hope this is a result of the previous Techstream attempts and is normal....
  7. #1567
    Aug 2019
    Quote Originally Posted by guillermemosz View Post
    Do you know where this is located in the car? Or can it be intergrated together with the smart key ecu ?
  8. #1568
    Mar 2016
    To my limited knowledge, Prius/Aqua models for regions outside the USA have ID Code Modules located near/behind the Evaporator core. It sounds to be an extensive job. I hope you have small hands
  9. #1569
    Mar 2015
    Default landcruiser 2016 all key lost
    Please can someone help me add this key data to landcruiser 2016 smart key ecu with 93c66?
    thanks in advance
  10. #1570
    Mar 2016
    Hello friends, as a follow up to a previous post I made, I have attached three 93c86 eeprom dump files from a USA 2011 Prius with Smart Key module 8990-47061. An original dump from the Smart Key module after I attempted to learn with Techstream and failed, a second "virginized" dump that I got from another DK member, and a third dump of the Smart Key module after I added a fresh key. PLEASE MAKE NOTE: that the transmission control module RH56 dump was all "0000" when I checked, which could be from my Techstream attempts. ALSO: I had the wrong key at first, call Toyota with your VIN to get the right part number, they have like 4 different keys listed for this 2011 Prius. Would have saved me a lot of time if I had called Toyota first. Enjoy.
  11. The Following 2 Users Say Thank You to morrisgauge For This Useful Post:
    freefallingegg (21st October, 2019), urcarpc (10th April, 2023)
  12. #1571
    Sep 2016
    Hello.i need help to reset data for THEFT WARNING box 89730-50130 93C76 Lexus LS430 2003
  13. #1572
    keymax's Avatar
    I'm working on a 2012 IS250. It was an all keys lost situation. Reset the immo and add first key (unlocked). The smart functions work correctly and i get ignition on but the immo light blinks even with ignition on. The steering lock never unlocks and the car won"t start. I tried resyncing the Steering and ID code box. It says successful but same situation. When I tried to reset again it finishes with success but there is still the one key stored in the system and it still works the same as before. I've tried a new steering lock and no change. I tried adding a key with tango directly into the smart ecu but it doesn't recognize the file. I pulled the ID code box and tried to resync both it and smart ecu but the Smart ECU is the wrong size.
    Smart Ecu #89990-53131 s93c86 File Size 2048b
    ID Code Box 89784-53031 S93c46
    can anyone have a look and help?
  14. #1573
    keymax's Avatar
    I also have this read from the Smart ECU. This was read off the board after I got back to the shop. I read the first incurcuit after I removed the resistor attached to the 5th and 8th leg while in the van.
  15. #1574
    Oct 2015
    Here u go with the reset. Pass in PM n don't forget to report back.
    No Thanks, No Report = No HELP
  16. The Following User Says Thank You to usman4 For This Useful Post:
    keymax (28th September, 2019)
  17. #1575
    keymax's Avatar
    Quote Originally Posted by usman4 View Post
    Thanks so much. I’ll try it tonight and let you know.
