Page 109 of 125 FirstFirst ... 95999104105106107108109110111112113114119 ... LastLast
Results 1,621 to 1,635 of 1871
  1. #1621
    GEORGIA , TBILISI
    Hi, What memory is there, and how to read it ?
  2. The Following User Says Thank You to GIODIAGNOS For This Useful Post:
    Abed qadah (19th January, 2020)
  3. #1622
    Apr 2014
    Quote Originally Posted by GIODIAGNOS View Post
    In MCU 70F166, use Tango+ read by OBD and make Key with Emulator
  4. #1623
    Apr 2014
    Quote Originally Posted by greenguy View Post
    I have a UK Vitz 2007 model which has had all the keys lost.
    The key and certification ECU replaced with used items.
    The key works (locks/unlocks the doors) there is ignition and the green light comes on BUT car won’t crank or the steering does not unlock.
    ‘DTC B2288 - Steering lock unlock waiting time over’ is in the main body ECU.
    I have read many post with you guys reprogramming used units back to virgins.
    I believe this maybe my issue.
    How do I this?
    What tools do I need to get these files?
    As an alternative can I try to force on the ignition and try programming the key only after reinstalling the old certification ECU?
    Reset ID code BOX, and make sincronize Ecu COmunication ID, betwen certification ecu and ID code, last short bridge OBD 4-13 with Ignition ON within 30 Minutes,
  5. #1624
    Jan 2020
    Ghana
    please i need solution for Toyota Yaris 2017 smart key and its all key lost situation
  6. #1625
    Hello Mate,
    Please need help in adding the key data attached to the Smart box dump also attached, or transponder data Page 2. 3 and 4 from the dump to be written in a CN2 Transponder
    Best Regards
  7. #1626
    Default Toyota Landcruiser v6 2008 Smartkey Lost
    Hello Friends
    toyota landcruiser v6 2008 all smart keys lost
    smart key 89990-60031
  8. #1627
    May 2015
    algie
    I will find the solution for you, do not worry
  9. #1628
    Quote Originally Posted by HAITEM1234 View Post
    Hello Friends
    please i need solution for Toyota smart key and its all key lost situation
  10. #1629
    Mar 2017
    Tallinn, Estonia
    good evening. Maybe someone could point me ,from which to start i have problematic lexus gs300, 2006, this car was a different so called indies and still no start. situation : one smart key, ignition goes on, button lights amber,no crank, only error is in ecm - b2799, should i reset transponder ecu 89764-30010, or also ecm 89666-30370, or also smart ecu 89990-30040, i took out transponder ecu also allready,this was all dash out of the car job. thanx for listening
  11. #1630
    Mar 2017
    Tallinn, Estonia
    jumping wires in obd for 30 minutes no result,also check engine light doesnt gome on,i noticed,but ecm communicates
  12. #1631
    Apr 2019
    Please help.
    Toyota Yaris S Limited 2008 Smart Key.
    Need Virgin file.
    And how to unlock used transponder key please?.
    Thanks before.
  13. #1632
    May 2016
    Hi all mates
    I have problem with Toyota smart key 2018 and above
    Smart key P/N
    89990-42090
    MCU
    D70F3584(A1)
    All key lost
    Dealer say that I have to change
    -Smart key
    -Smart remote
    -Steering look
    -Immobilizer
    Any way one of did it before and how??
    Thanks for help and support
  14. #1633
    May 2016
    Did u find any solution??
    Plz inform me
    WhatsApp
    +966505669811
  15. #1634
    Sep 2016
    Quote Originally Posted by alghrooob View Post
    Hi all mates
    Smart key P/N
    89990-42090
    MCU
    D70F3584(A1)
    All key lost
    -Smart key
    -Smart remote
    -Steering look
    -Immobilizer
    Can you make pictures of smart key module inside?
  16. #1635
    Jan 2019
    Hi friend.
    I have 2016 Toyota Avalon smart push button key (all keys lost)
    I have NEW BLANK toyota key on hand.
    I have fast laptop, teamviewer, Autel J2534, X300DP tablet, Codiprog to read EEProm and FVDI 2020.
    Can you help me make this car run?
    Cheers.
