Are you still able to power on ignition with the start-stop button? If the not the Smart key ECU is locked. Need to Virginize both id code and smart key ECU on bench. Best of luck
pizz (30th May, 2020)
Thanks for the advice. Thats why l send the dumps so that someone can help me virginise them.
I think the better way is to read your Smarkey data and post here
P1
P2
P3
P08
someone will register your Smartkey to Smart ECU
Then use the smartkey to power the car and reprogram it by OBD II
edit:
I see your ID code File was already reseted
Try this reseted smart File
Reseting ID code box and Smart ECU will not syncronize to Steering and engine
You need to re sync also these ECU
P1 94
P2 39
P3 7A16F4 1A
P08 9430647B97
These are the details. thanks in advance
Hello Mate,
Please can someone help me with Page 1, 2, 3 and 4 Transponder Data to be written in a CN2 from the dump attached.It is from the Smart dump of a Toyota Vitz
Here is the file
After writing it to smartbox, push the start button using your Smartkey to On the ignition.
and program the smartkey using any tool via OBD
Note: Your ID Code box , as your posted dump was already reseted, it need to syncronize to engine ecu and steering
pizz (31st May, 2020)
Thanks hcip for your support l finally managed to do the car. As you said. I used Lonsdor to program and sync the steering lock and ecu, l D box it was so easy.
Does anyone can help me please?
Hi everyone I need help I don’t know code my radio smart MC761131415719 thank for help me
rybenz (12th June, 2020)
